 | Cropping a heavily animated comp.
on Dec 29, 2016 at 4:36:34 pm |
I make animations with several layers contacting keyframed/expressioned scale/position/rotation etc. This creates an issue when I want to crop in on part of the window.
My current method is to make a null object, parent everything to it (or if some things are already parented, parent the lowest of them) and change its position/scale as needed. So far this has been working perfectly well but I am wondering if there is another less crude method for this, I have no knowledge of the unified camera tool, is that where I should look or is it more for 3d?
PS: Putting the entire comp in a new comp and making the crops there is not desirable, I already have many comps within comps so doing this is very processor intensive and results in a loss of resolution (my original footage is 4k, I Shrink it to 1920*1080 to animate, so cropping in on the 1920 comp loses the 4k).
Any tips/input is appreciated!
 | Re: Cropping a heavily animated comp. on Jan 3, 2017 at 8:13:12 pm |
[John Winthrop] "My current method is to make a null object, parent everything to it (or if some things are already parented, parent the lowest of them) and change its position/scale as needed. So far this has been working perfectly well but I am wondering if there is another less crude method for this, I have no knowledge of the unified camera tool, is that where I should look or is it more for 3d?"
Doing this with 3D layers (even if they're mostly for 2D moves) will let you use a camera for more intuitive control.
Walter Soyka
Designer & Mad Scientist at
Keen Live [link]
@keenlive [twitter] |
RenderBreak [blog] |
Profile [LinkedIn]
