How is movement done in a shot in after effects
Sahil Zafar
on Dec 28, 2016 at 10:31:23 pm
I have seen many videos where the camera quickly shifts from one place in the shot to another (in the same shot) with motion blur added, like in this video several times (https://vimeo.com/108018156 especially 1.15.-1.18). This can also be used in a transition as it is done here (https://vimeo.com/108018156 0.43-0.46 good example). How is this done in after effects?
Greg Gesch
Re: How is movement done in a shot in after effects
on Dec 28, 2016 at 11:54:08 pm
Hi Sahil, the links didn't work for me but it sounds like you mean a whip or swish pan. This is a very simple way to do it though there are more advanced tutorials around as well:
Sahil Zafar
on Dec 29, 2016 at 8:57:48 am
Yeah! That's what I was look it for. But can this be used in the same shot by duplicating the video layer and zooming in? (https://youtu.be/fhFqEDZ2kB4) the video is called "Watchtower of Turkey" it's a beautiful video with lots of quick pans and zooms.
Greg Gesch
on Dec 29, 2016 at 11:15:39 pm
Hi, that clip is a beautiful example of the editor's art. I'm not sure what you mean by duplicating the video layer and zooming in? You can mask out a section of the image (say a doorway) and zoom through it to see another clip. Since you know the look you want you would need to experiment and see what works. There is a lot of skill that has gone into that clip (one of the great strengths is the use of, and matching of, colors).
Sahil Zafar
on Dec 30, 2016 at 1:03:38 pm
That video is indeed a work of art. But what you said about zooming through a doorway, is that using a camera layer?
