How to remove a thick-wire from shot?
Tom Headle
on Dec 23, 2016 at 8:45:08 pm
In this case, the "wire" removal is a thick chain.
See shot here ( BLUE "Download File" to see P1430042_1.mov) :
https://expirebox.com/download/c8eb837045ab58a474494162f4d1cfe3.html
The chain that is holding up the climber needs to be cleanly removed.
Everything I tried leaves artifacts and just ends up not looking real and clean.
I'm looking for pointers from the AE experts here as I have tried these two separately and together, no luck.
CC Simple wire removal
Clone stamp
I've tracked it and tried at cut a clean plate (from this footage) and use it as a proxy on top of the chain
and roto'd out the climber - still looks horrible ☹
Advice ?
Thanks in advance,
TH
chris brett
Re: How to remove a thick-wire from shot?
on Dec 23, 2016 at 10:27:59 pm
-- Hi Tom -- this might be worth a try if you havent already given it a go.... possibly its an answer .. not sure...
I once did a tricky shot, with some similarities, on Flint where there is a 'buy and sell' function
.......you load 3 clips - foreground, matte and background and you can paint the matte frame by frame and it reveals the bottom clip through the top clip......
Whats good about this is that the bottom clip can be the same as the top clip only you slip it a frame or two so that it you 'paint out' things with the same clip .
You can do this in a number of passes as well so that if a bit isnt quite right the first time round you can render and get it on a second pass........the trick is to be fairly accurate with the matting, use a soft edge and dont slip the fill too much or you will see it.
-------- an AE version of this might be worth a try ( ? ) though not sure if the camera move is too much for this ---
----------------------------------------------------------------------------------- chris ---
Tom Headle
on Dec 24, 2016 at 12:36:16 am
Hey Chris,
Thank so much for your quick reply & suggestion - you exactly see the issue @ hand.
I started leaning in the frame-by-frame paint but didn't think of it in your terms; I believe that's a great approach.
Take care,
Tom
Lance Moody
on Dec 23, 2016 at 10:40:12 pm
It's a near perfect job for the Mocha Insert/Remove tool.
Lance
chris brett
on Dec 23, 2016 at 11:02:33 pm
-- apologies -- my idea does not work - just tried it ---c---
Roei Tzoref
on Dec 24, 2016 at 1:41:21 am
1. 3d camera track the shot
2. find a suitable target and place a solid. make sure it covers the chain (don't scale it, use solid settings for it)
3. precomp the solid->leave all attributes- call it "CleanPlate" put the texture inside (clean the some in Photoshop)
4. roughly mask the precomp with some feather, don't worry about a bit of overlap with the guy just don't make it too big
5. duplicate the footage, mask the parts of the guy that are over the cleanplate
you can do it better
Project File:
10900_climbingwall.aep.zip
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
chris brett
on Dec 24, 2016 at 11:06:12 am
...excellent explanation Roei ---- I shall remember that well ---- chris ---
Tom Headle
on Dec 24, 2016 at 6:36:59 pm
Whoa, extraordinary. That is perfect - I can't thank you enough Roei !!!
This site never ceases to amaze me...
Roei Tzoref
on Dec 24, 2016 at 6:52:37 pm
Sure thing Tom! you're welcome and thank you for the practice ☺
Roei Tzoref
