CC Ball Action doesn't work on subcomp
Cugeeno Benatti
on Dec 18, 2016 at 4:10:52 pm
Hi everybody,
I have a problem using the CC Ball Action in After Effects.
I am working on a composition (Call it A) that contains another one with a green screen in it (Call it B). The main problem is that when I apply the CC Ball Action on the A comp, this affect the image except for the place where the green screen was. It looks like the plugin doesn't recognize the precomp as a whole scene but it still analyze it as two different levels.
Here a screenshot:
Does anyone have an idea to fix it?
Daniel Waldron
Re: CC Ball Action doesn't work on subcomp
on Dec 18, 2016 at 7:31:12 pm
Sounds like you have the Collapse Transformations box checked. A screenshot of your whole workspace could help identify if that is or isn't the issue.
Cugeeno Benatti
on Dec 19, 2016 at 5:56:48 pm
Hi Daniel,
thanks for the answer.
Here the workspace. On the left side the composition where I applied the green screen, on the right side the one where I applied the CC Ball Action. No Collapse transformation box is checked, still the green screen level disappears.
Walter Soyka
on Dec 20, 2016 at 10:57:47 am
Is there a mask on that layer?
Walter Soyka
Cugeeno Benatti
on Dec 20, 2016 at 11:26:01 am
On the layers where I used the CC Ball Action there are no masks. In the subcomps there are some masks but not where the screen disappears!
