Trim multiple layers keeping start points?
Jerry Smith
on Dec 16, 2016 at 12:39:44 pm
Trying to speed up render times. If I have a bunch of layers that don't need to overlap and go up in a staircase, is there a quick way select them and trim each so that it ends just as the next step begins? I thought that there would at least be a 3rd party script, but I don't see one.
Roei Tzoref
Re: Trim multiple layers keeping start points?
on Dec 16, 2016 at 6:46:08 pm
if their opacity is 0 at those overlapped areas, it would not make a difference in render times (or at least it's not supposed to) . as for trimming you can hold the shift key and manually drag the edges and they will snap. for automatic trimming try this: http://aescripts.com/obsessive-layers/
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
Greg C Neumayer
on Dec 16, 2016 at 10:40:03 pm
Do a search on "trim" in aescripts.com. I think there are a few different solutions, depending on what you want to do.
