How to extend animation in a project with many layers?
Pavel Vanchugov
on Dec 12, 2016 at 9:57:07 pm
My client often asks me to extend some animations in the middle of the project in 1 second. That requires not only moving keyframe on target layer in 1 second, but also moving all keyframes after that moment on all layers. I am doing it manually, and it's really long. Is there a better way?
Monk Ng
Re: How to extend animation in a project with many layers?
on Dec 13, 2016 at 1:53:44 am
http://aescripts.com/rd-compsetter/
This is an aescript that can adjust composition setting for multiple comps at once.
What Dave suggests is also a great practice. The best part is you can also pre-render each comp for a faster output!!
Pavel Vanchugov
on Dec 13, 2016 at 8:36:00 am
http://aescripts.com/elastic-comp-changer/ doing what i searched for. Thank you for your answers. Pre render comps means render and replace videos with compositions? Or it's a preview RAM render?
Monk Ng
on Jan 9, 2017 at 2:28:41 pm
Sorry for the late reply.
Yes it means render and replace the comp. This will make preview and final render faster. Just make sure you have good file management to make sure you have correct sequence for final output.
