Best way to make a node based flat comp which undulates (possibly use Plexus?)
craig hellen
on Dec 10, 2016 at 7:29:51 pm
Hi guys
So I have a trangular node based piece of branding from a client and we want to do 2 things.
1)
Have a gentle wiggle applied to the "mesh" and have all the nodes and lines stay connected.
2)
Be able to pull a camera in (or just scale to get the effect) to have icons placed in each node point.
There are 2 screens which I hope help illustrate this:
I do have plexus but I don't know if we can get it to behave as a flat layer and be able to navigate to and keep the camera focused on different points.
Any help is appreciated!
Craig
Co-Director Podchains Ltd
Video Producer / Motion graphics designer http://bexmedia.net
Greg Gesch
Re: Best way to make a node based flat comp which undulates (possibly use Plexus?)
on Dec 11, 2016 at 11:23:53 pm
Hi Craig, how do you want the mesh to look when it undulates/wiggles? It might be something as simple as using the Bezier Warp effect (or any of a number of effects in the Distort menu) you might also look at the Puppet tool. For the zoom, as you say, you can just scale up and pan & scan. As long as you are using vector graphics they will remain crisp - are you having a particular problem?
Matthew Keane
on Dec 14, 2016 at 10:28:48 am
That triangular mesh does indeed look very plexus-like. If you recreate your mesh using 3D Nulls at the same Z position, Plexus will give you a flat mesh of connected nodes (depending on the Plexus renderer you choose). You can add a noise effector for a gentle undulation (only in the XY axes, if you prefer) and then move the camera around it as you wish, so yes, it should work.
