3d layer flickers
Iwan Smith
3d layer flickers
on Nov 30, 2016 at 4:00:29 pm
10834_3dlayerflicker.mp4.zip
Hi guys,
Do you have any ideas how to lower this flickering? This is a 30fps render if I set it to 60fps its better but I would like to keep the 30fps
http://iwansfactory.com
Motion graphics portfolio
Iwan Smith
Re: 3d layer flickers
on Nov 30, 2016 at 4:14:10 pm
I disabled motion blur and depth of field, changed color depth to 16 and 32 but nothing helped
chris brett
on Nov 30, 2016 at 5:19:55 pm
Hi Iwan
----- had something similar before and solved it by making sure the input data and fields were set correctly - this info is found by going to project folder / right click on item / then 'interpret footage' / 'main'
-------------------------------------- chris
Iwan Smith
on Nov 30, 2016 at 5:37:45 pm
Hi Chris
I am using images on the side of the boxes so fileds doesnt matter there but thanks for the reply :)
Walter Soyka
on Nov 30, 2016 at 6:02:15 pm
The problem is caused because the position of the objects is changing too much from frame to frame; because each object jumps so much from frame to frame, it breaks the illusion of continuous motion.
1. Turn on motion blur. Maybe crank it up a bit.
2. Slow down the pace of the move, so there's less change from frame to frame.
3. Crank up the frame rate, so there's less change from frame to frame.
More information here:
http://kb2.adobe.com/community/publishing/908/cpsid_90843.html
Walter Soyka
Iwan Smith
on Dec 1, 2016 at 8:45:17 am
Thanks Walter for the detailed answer its correct, I need to slow down the pace of the move
