Text Bounce and Squeeze
Carlos Morelli
on Nov 29, 2016 at 4:14:29 am
Hello everyone. I'm trying to achieve this effect, especially the yellow text:
May some expression be involved?
I believe there are scale, rotation, position and tracking properties being animated, and probably this text layer is parented to the speech bubble, but I can't get quite there.
Any suggestion would be appreciated.
Thanks in advance.
Dion Mei
Re: Text Bounce and Squeeze
on Nov 29, 2016 at 5:21:29 am
It could be the wiggle effect
John Cuevas
on Nov 29, 2016 at 1:48:38 pm
Looks like what is happening is over shoot. When I do this I use a control layer, since I'm usually working on multiple layers of objects, but can you apply this expression directly to any keyframeable parameter, set your frequency and decay, then add a couple keyframes to get this action.
freq = thisComp.layer("Control Layer").effect("Freq")("Slider");
decay =thisComp.layer("Control Layer").effect("Decay")("Slider");
n = 0;
if (numKeys > 0){
n = nearestKey(time).index;
if (key(n).time > time) n--;
if (n > 0){
t = time - key(n).time;
amp = velocityAtTime(key(n).time - .001);
w = freq*Math.PI*2;
value + amp*(Math.sin(t*w)/Math.exp(decay*t)/w);
}else
value
Here is a project where I use a control layer.
10830_scalebouncecontroller.aep.zip
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Chris Buttacoli
on Nov 29, 2016 at 2:12:24 pm
Keyframing this by hand, while not impossible by any stretch of the imagination, certainly wouldn't look as natural as using a sine wave decay expression like John's above. Using this to control the horizontal scaling of the text only, with the anchor point right justified, should get you the yellow text effect you're looking for.
Carlos Morelli
on Dec 3, 2016 at 4:36:41 am
Sorry for the late response, but thank you all for the suggestions!
I'll see what I can do.
Roei Tzoref
on Dec 4, 2016 at 1:30:33 am
if you are interested on how to do this manually without code, I would suggest you study about the graph editor.
here are 2 good resources:
http://www.schoolofmotion.com/intro-to-animation-curves-in-after-effects/
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
Carlos Morelli
on Dec 4, 2016 at 4:47:56 pm
Thanks a lot for the advice! I must admit I never really bothered to use this feature.
