importing assets
chris brett
importing assets
on Nov 23, 2016 at 10:33:52 am
Hi
- have 2 very large projects and I want to import some of the assets of one into the other
- any suggestions please on best workflow
------------------------------------ chris --
chris brett
Re: importing assets
on Nov 23, 2016 at 10:46:38 am
-- sorry - should have been more precise '' importing some assets, some comps, and some of the setups...''
--------------------------------chris --
chris brett
on Nov 23, 2016 at 11:41:50 am
--------------- sorted !
Krishna Moorthy
on Nov 23, 2016 at 2:45:32 pm
You must import one .aep file into other and then use whatever assets you need. Then, reduce the project with your main comp. Hope this the solution as far I understood your situation.
chris brett
on Nov 23, 2016 at 3:09:55 pm
-- thank you Krishna -- will remember that
-- a bit more elegant than what I ended up with -- many thanks ---c----
