Is it possible to sync two video clips. As if they were both a locked off shot.
Chey Anich
on Nov 21, 2016 at 8:41:06 pm
I have a question that i’m completely stuck with!
I have filmed a shot twice, the same motion. Is there a way to sync up both video clips? like it would be if the camera was locked off. I want to be able to mask the first layer while keeping it seamless with the second layer.
Any help will be really appreciated.
Daniel Waldron
Re: Is it possible to sync two video clips. As if they were both a locked off shot.
on Nov 22, 2016 at 2:29:35 pm
Can you give more info? It is very unclear what your shots are and what you are having trouble with.
If you shot something twice, sync the layers on top of each other and mask where you want. If there is motion you could try using time remapping to match the timing, but that is hit or miss.
