I NEED H3LP-After effects transition effect
Roman Hudaj
on Nov 20, 2016 at 9:41:56 pm
I've been looking absolutely everywhere to learn how to do this technique but i cant find anything at all.
SO, basically i want to merge two videos together. The two videos are taken on a tripod. The camera is turning horizontally until it a wall passes by. After it passes the wall i want it so that the next place shows up from behind the wall and it keeps on turning .Sort of like jumping from one place to the other. Or turning a corner and being in a completely different area,
The best example i could come up with is this video----------
If you skip to 0:53,
this is basically the effect i'm looking for.
PLEAS HELP, THANKYOU!
Greg Gesch
Re: I NEED H3LP-After effects transition effect
on Nov 21, 2016 at 10:40:33 pm
Hi Roman, all you need do is draw a mask around the element you want to reveal the layer underneath. In your example the rear of the truck would be masked so as it passes the playground is seen.
