Warp Stabilizer on only portions of clips
Dan Tran
on Nov 20, 2016 at 10:15:30 am
I have a few long take clips that I'm working on that are generally smooth. However, there are sections of the clips that can be bettter stabilized. I'm trying to avoid stabilizing the whole clip as the cropping involved wouldn't be ideal and the takes are so long. I've split up the clips in sections and did it that way but matching the frames at my edit is virtually impossible. Is there a way to better do this? Is it possible to keyframe the Warp Stabilizer?
Dhanush Dhanush
Re: Warp Stabilizer on only portions of clips
on Nov 20, 2016 at 10:36:11 am
You can split the clip and apply warp stabiliser only to that clip!
Dan Tran
on Nov 20, 2016 at 4:54:32 pm
Hi Dhanush, I've tried that but how do I best align my frames at the split? The warp stabilizer slight distorts my image.
Roei Tzoref
on Nov 20, 2016 at 11:43:42 pm
[Dan Tran] "Is it possible to keyframe the Warp Stabilizer?"
not without a long process. see it here: http://lesterbanks.com/2013/07/converting-after-effects-warp-stabilizer-to-...
I think in a case where I need the stabilization to fade, I would use the point tracker or Mocha for stabilizing instead trying to convert my WS to keyframes.
keyframes for WS could be a useful feature for, you can ask for it here. http://www.adobe.com/products/wishform.html
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
