Force realtime playback?
kit webster
on Nov 19, 2016 at 1:14:17 pm
I am working on a composition to a musical track that requires the music to be played back in realtime.
Is there any way I can force After Effects to playback in realtime? I remember I used to be able to do this before I upgraded to CC 2015.
Roei Tzoref
Re: Force realtime playback?
on Nov 19, 2016 at 2:14:06 pm
it should work. not that on some Mac system there has been a playback problem that was only fixed by the recent 14.0.1 update (CC 2017) https://blogs.adobe.com/creativecloud/after-effects-cc-november-2017-bug-fi...
setting your preview panel this way makes sure it will behave like the familiar RAM Preview prior to CC 2015:
notice the cache before playback option.
see if that works for you
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
Eric Santiago
on Nov 21, 2016 at 4:50:35 pm
Does the above work?
I dont seem to get it to work at all.
Roei Tzoref
on Nov 21, 2016 at 9:22:23 pm
what do you mean. what results are you seeing? and what version are you using exactly - full numbers?
Roei Tzoref
