RAM Allocation per background CPU?
Adrian Vayn
on Nov 18, 2016 at 9:49:13 am
I would like to know what are the best settings for this? I don't quite understand what this does, so could you help me ?
Walter Soyka
Re: RAM Allocation per background CPU?
on Nov 18, 2016 at 11:13:56 am
Multiprocessing (the "Render multiple frames simultaneously" feature) launches background instances of the After Effects renderer. Each instance can render one frame at a time, and each instance is separate, loading its own private copy of your project into its own private area of RAM. The "RAM allocation per background CPU" dictates the minimum amount of RAM that must be available to each instance of the renderer.
Although there is no "right" setting for this -- RAM usage is highly dependent on what it is you are rendering -- I think that your settings are entirely too aggressive, and that by asking so many instances to use so little RAM each, with so little RAM left over for the operating system, you are probably actually slowing your renders down. I suggest leaving a quarter of your RAM available for other applications, and using a higher allocation per background CPU. This may leave you fewer instances, but each one will be able to work much more efficiently.
Walter Soyka
Adrian Vayn
on Nov 18, 2016 at 1:18:21 pm
i left so little ram for the system cause i have 2 computers and while im rendering i switch to other pc, also i've put 2 GB on allocation and now i seem to get constant 100% cpu usage, is this fine or should i increase the allocation?
Walter Soyka
on Nov 18, 2016 at 1:22:55 pm
[Adrian Vayn] "i left so little ram for the system cause i have 2 computers and while im rendering i switch to other pc, also i've put 2 GB on allocation and now i seem to get constant 100% cpu usage, is this fine or should i increase the allocation?"
If your car is stuck in mud and you stomp on the accelerator, your wheels will spin. Your engine's RPMs will shoot up, but you won't actually go anywhere.
Your goal is the fastest render, not the highest RAM or CPU utilization.
I'd suggest leaving more than 3 GB for the OS and see if it improves your overall performance.
Walter Soyka
Adrian Vayn
on Nov 18, 2016 at 1:40:22 pm
CPU for other applications
RAM for other applications
Which one? and how much
Alex Lindblom
on Nov 18, 2016 at 2:08:17 pm
Well for CS6 it's very well explained in this link. The good stuff is at the end.
https://tv.adobe.com/watch/digital-video-cs6/how-to-optimize-after-effects-...
I use to same set up on 32 gig system and it works fine.
6 GB for other applications
4 real cpus, in your case it will be 6 cpus he explains why in the video.
3 GB per core and you can afford 4 GB since you have more memory.
Adrian Vayn
on Nov 18, 2016 at 2:22:15 pm
Is this better? or should i lower the RAM allocation
Walter Soyka
on Nov 18, 2016 at 3:59:56 pm
Try some test renders and see if they're faster.
Walter Soyka
Adrian Vayn
on Nov 18, 2016 at 6:22:00 pm
alright this is what i put
RAM reserved for other applications - 8GB
CPUs reserved for other applications - 2GB
RAM allocation per background cpu - 2GB
and i seem to get overall best performance, is this good setting?
Adrian Vayn
on Nov 19, 2016 at 8:34:43 am
Anyways i was testing yesterday and these are probably best settings now that i've got, what do you think?
Walter Soyka
on Nov 19, 2016 at 3:35:38 pm
I think if that's giving you the lowest render times, then those are good settings.
Again, there are no hard and fast rules; a lot of this is dependent on what you are rendering. I have had some projects where I had to reserve a minimum of 12 GB per background CPU; others have been fine with 3 or 4 GB. If you've found something that's working well for you, go for it!
Walter Soyka
Adrian Vayn
on Nov 19, 2016 at 4:55:00 pm
this works perfect it cut renders by half ;)
