Composition shadow on floor in 3D 'studio'
Niels Rask
on Nov 17, 2016 at 2:47:37 pm
Hi everybody, hope that you guys can help here.
I am displaying a composition in a 3D 'studio'. I would like the composition elements to create shadows on the 'floor'. They are simple AI elements that move across the com position.
In relation to that I am also inserting a video in the 'studio', I would like the 'screen' to also cast a shadow on the fllo of the studio.
Fingers crossed and many thanks in advance!
Walter Soyka
Re: Composition shadow on floor in 3D 'studio'
on Nov 18, 2016 at 12:05:28 pm
This is very easy to do with 3D layers.
THE FLOOR
Create a solid that will be your floor. Make it 3D, rotate it, and move it down to the bottom of the studio. With the floor layer selected, press AA to reveal its material properties in the timeline and make sure that it is set to accept shadows.
THE ELEMENTS IN THE STUDIO
For all your other Illustrator layers, make them 3D. Position them in space where you like (you may need to use multiple 3D views to make sure they are positioned correctly). Press AA to reveal material properties and make sure that each of these layers are set to cast shadows.
THE LIGHT
You won't have shadows unless you have a light to cast them. Add a light layer to your scene, press AA, and make sure it's set to cast shadows. Position as necessary.
ADDITIONAL READING
Here are some links to helpful sections of the Ae reference:
Use 3D layers in After Effects:
https://helpx.adobe.com/after-effects/using/3d-layers.html
Cameras, lights, and points of interest:
https://helpx.adobe.com/after-effects/using/cameras-lights-points-interest....
Walter Soyka
