Motion Tracker seems to have hung
Bruce Gaber
on Nov 15, 2016 at 12:11:12 am
I'm working thru the motion stabilization tutorial from "Creating Motion Graphics". I've gone thru all the steps including "analyze" which gave me a tracking path just as shown in the book. All the keyframes are generated. But when I hit "apply" I get a blue bar across the the comp screen that says "Analyzing in the background (step 1 of 2)" And it is taking a very looong time. Any idea of what is happening here?
Bruce
Photographer / Motion Graphics Artist
Vision Rising
vimeo.com/BodhiBruce
visionrising.com
Dance Without Reason
Daniel Waldron
Re: Motion Tracker seems to have hung
on Nov 15, 2016 at 1:14:07 pm
What's the resolution and file format of the clip you are tracking?
Krishna Moorthy
on Nov 15, 2016 at 5:16:05 pm
Hey dude,
Hope you are using "Warp Stabilizer". If you apply warp stabilizer for shaky footage, after effects will stabilize the footage automatically. Just sit back and relax, it will give you a stabilized or less shaky footage. If you think, it consumes more time, then you may use stabilize motion in which you have to manually pick a track point to stabilize the footage.
Reply if you have any doubts.
Krishna,
Behance: Behance
Twitter: Twitter
Michal Wiczynski
on Mar 16, 2017 at 4:57:30 pm
Having same issue (H264)
Filesize : 97GB
Length: 54minutes
Resolution: 1080p
CPU and RAM were working hard for 5hrs, analysed all the frames and then nothing. Still can see the blue ribbon.
Current status:
CPU: 0%
RAM: 6GB in use (16GB max)
