Specific matte question
Skylar Moran
on Nov 14, 2016 at 10:42:40 pm
Hello,
I am trying to recreate a rather retro effect, but for some reason I am banging my head against a wall trying to find a simple solution to create it.
I have this text with a heavy shadow effect on it. Here's a screengrab.
I want to have the white part of the text wipe on and reveal the orange shadow. I have each on separate layers. I tried using the echo effect on a matte of the text part to create a wipe-on effect, but that isn't working as smoothly as I hoped, so here I am searching for another creative idea. Any takers?
chris brett
Re: Specific matte question
on Nov 15, 2016 at 12:07:50 am
Hi Skylar
---- I dont think its clear what you are trying to do - if you mean...
1 ) wipe on type with outline and fade up extruded flat drop shadow then :
---- draw a mask over the type and set it to subtract - this will mean you can not see it
---- go to start of animation and set keyframe on mask path
---- go to end of animation and select 'mask path' to drag the left hand side of mask to the right revealing text ( if left to right ) - set feather to suit if wanting soft edge
--- go to other layer with drop shadow and animate transparency to suit
2 ) If you mean 'grow' the drop shadow from the type with the outline then you will be able to do this using a custom matte ( you could just draw this with the pen tool or go to PS for a black and white ) --- just slide it in from 'behind' the type by selecting the custom matte as the track matte -- you might need a version of the drop shadow with the outline and type as well ( set to orange ) to make the join easy
.... I guess you could do this with C4D but I think it will be hard to match the flat retro look ( ? ) --- I dont use it myself so I could be wrong ( ? ) -- however if you like the 3D look you can also do this in an older version (s ? ) of AE that have the 3D option ( where you can extrude vectors as in a dedicated 3D package )
---------------------------------- good luck ---- chris
