Disable AE 2017 project conversion warning
Kirill Skorodelov
on Nov 11, 2016 at 11:33:45 am
Hi all, does anyone know how to disable a warning when you open a project made in older version of AE if it is possible at all? I know it's a standard warning which existed forever in but for my workflow reasons I'd like to disable it. I upgraded to AE2017 and of course all the projects created earlier in AE2015 are opened with this warning.
Thanks a lot in advance,
Kirill.
Roei Tzoref
Re: Disable AE 2017 project conversion warning
on Nov 11, 2016 at 4:57:04 pm
I never heard of a way to disable it. as a workaround you could just save the project again over the original and now it will be CC2017 and not produce a warning when opening.
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
Michael Szalapski
on Nov 14, 2016 at 4:31:00 pm
I would recommend against saving over it. It probably won't cause an issue, but it's always better to be safe than sorry. I mean, I usually use the increment and save feature more than necessary too! I figure it's just better to increment the file name after any big changes and I'd do the same in this instance.
- The Great Szalam
Roei Tzoref
on Nov 14, 2016 at 4:57:46 pm
definitely you should create backups for your projects. usually if I want to stay organized and create templates I would not use the increment method. but to keep organized I would create a folder called "Old" and save other versions.
Roei Tzoref
