Cinema 4D to AE (AEC Framerates are not Matching)
Dennis Hua
on Nov 10, 2016 at 7:11:39 pm
Hi, I'm pretty new to using AE and C4D and im struggling to move the C4D project file into AE. I already managed to get the plugins from MAXXON and made sure that the framerates between the two program are set at 30FPs and I set the output from 0-157 frames, but I when I import the AEC file into AE it only imports up to 7 frames. Am I doing something wrong? I am also using CS6 instead of CC
Cassius Marques
Re: Cinema 4D to AE (AEC Framerates are not Matching)
on Nov 11, 2016 at 1:22:05 pm
Do you have anything animated on the c4d project after those 7 frames? From what I remember the exporter only exported frames that had animation.
Also I had plenty of trouble with that too. Usually you need to bake most of the animation to PSR.
The best I can do is check your cinema 4d file with cineware, because I no longer have access to cs6 and the old importer.
Cassius Marques
http://www.zapfilmes.com
Cassius Marques
on Nov 11, 2016 at 1:25:20 pm
And what do you mean with "Framerates are not matching" ?
Isn't your imported composition in AE set at 30fps too? Or did you meant just number of frames?
Cassius Marques
