How to make shapes/text explode in different directions?
Ryan Gibbs
on Nov 10, 2016 at 3:05:00 pm
I'm trying to make these letters go off screen as if someone is pushing them from the middle outwards:
What would be the best way of doing this? I've tried hand-animating, but it doesn't look natural.
(Side note: The letters are individual images I created in photoshop and brought in as .png's)
Any help would be appreciated! Thanks :)
- Ryan.
John Cuevas
Re: How to make shapes/text explode in different directions?
on Nov 10, 2016 at 3:14:04 pm
You can do that using the shatter effect.
https://library.creativecow.net/articles/unguren_ben/shatter.php
https://library.creativecow.net/articles/mize_rob/AE-Shatter-Effects/video-...
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Ryan Gibbs
on Nov 10, 2016 at 3:29:34 pm
Oh, I wasn't expecting that to work! Cheers :)
- Ryan.
Ryan Gibbs
on Nov 10, 2016 at 3:42:01 pm
I've run into a bit of a problem, it's splitting the inside and outside:
- Ryan.
Michael Carter
on Nov 10, 2016 at 9:28:51 pm
Is each letter two files? That could be your problem. The plugin is randomly scattering everything.
I'd find a way to bind them together if so - precomp each letter, for instance. Or do a set of PNGs where the white stroke and the inner color are one file.
Ryan Gibbs
on Nov 14, 2016 at 2:14:54 pm
I found out that shatter uses alpha channel to calculate the shatter, so as soon as I duplicated the comp, and made the second comp a solid red (instead of white+red), it worked perfectly.
But thanks for your help, I really appreciate it :)
- Ryan.
Soham Jani
on Nov 10, 2016 at 5:25:59 pm
I believe Andrew Kramer has a tutorial relating to shattering somewhere on his website?
"It's all around us Neo, temporary constructs of time....."
