Dynamic Compositionlenght
Marcel Scholz
on Nov 7, 2016 at 2:06:48 pm
Is it possible to make the Compositionlenght dynamic, so when i put a Song with 02:14 the Maincomp should set to 02:14.
Walter Soyka
Re: Dynamic Compositionlenght
on Nov 7, 2016 at 2:41:47 pm
[Marcel Scholz] "Is it possible to make the Compositionlenght dynamic, so when i put a Song with 02:14 the Maincomp should set to 02:14."
No. You can either make your main comp extra long, then simply set the work area when you add the song, or you can create a comp directly from the song by dragging the song item from the project panel onto the New Comp button.
Walter Soyka
