AE2017 not playing back
kit webster
on Nov 5, 2016 at 8:16:34 am
When I press the space bar the green render line grows but it doesn't preview
If i select 'cache before preview' it previews but only at the end of the green render line, not at current time indicator.
Marcel Scholz
Re: AE2017 not playing back
on Nov 5, 2016 at 6:23:30 pm
I have an other problem.
When I press 0 to cache the frames bevor preview.
Normaly to cache and stops only when i press 0 again.
Now it chache a second and plays that cached frames.
I cannot modify the lenght.
Michael Beck
on Sep 28, 2017 at 2:51:15 pm
I have this same problem in windows 10.
Can anyone actually helpful weigh in in this? Dave above has been less than helpful.
Derek Bavin
on Sep 28, 2017 at 6:56:41 pm
You could check your preferences for Media and Disk Cache and Memory and make sure you have enough resources allocated. You may need to adjust the settings.
Michael Beck
on Sep 29, 2017 at 12:23:03 pm
Thanks! I will take a look and see.
