Converting a layer to 3D via ExtendScript
Krishna Moorthy
on Nov 4, 2016 at 7:44:54 pm
Hey,
kindly help me out to use draft3d attribute in my script. I want enable 3D for a specific layer. I don't know how to use the draft3d attribute.
Thanks in advance!
Walter Soyka
Re: Converting a layer to 3D via ExtendScript
on Nov 5, 2016 at 4:28:19 am
[Krishna Moorthy] "kindly help me out to use draft3d attribute in my script. I want enable 3D for a specific layer. I don't know how to use the draft3d attribute."
draft3d is an attribute of comps, not layers. To make a layer 3D, set its threeDLayer attribute to true.
Walter Soyka
Krishna Moorthy
on Nov 6, 2016 at 6:01:40 am
Yeah, that's the thing I wanted to do. How set the draft3d attribute to true for a precomp.
Walter Soyka
on Nov 7, 2016 at 3:59:36 pm
[Krishna Moorthy] "Yeah, that's the thing I wanted to do. How set the draft3d attribute to true for a precomp."
It's pretty straightforward:
// replace with your own comp reference
myComp = app.project.activeItem;
// Enable the Draft 3D switch for the comp
myComp.draft3d = true;
Walter Soyka
Krishna Moorthy
on Nov 8, 2016 at 12:12:38 pm
Here is the exact thing which I wanted.
compReference.layer(1).threeDLayer = true:
Found this through Adobe After Effects Scripting Guide.
Thank you Walter.
Krishna Moorthy
on Nov 8, 2016 at 12:13:26 pm
Meanwhile, I want to know what is the usage of draft3d attribute. Kindly, explain.
Walter Soyka
on Nov 8, 2016 at 2:02:16 pm
[Krishna Moorthy] "Meanwhile, I want to know what is the usage of draft3d attribute. Kindly, explain."
From https://helpx.adobe.com/after-effects/using/previewing.html :
"Each preview mode provides a different balance between quality and speed for playback and for updating of images during interactions, such as when you drag a layer in the Composition panel or modifying a property value in the Timeline panel. Draft 3D and Live Update modes apply to all views of a composition. Draft 3D disables lights, shadows, and depth-of-field blur for cameras."
Walter Soyka
