Modifying speed graph, maintaininmg a "Linear" speed.
John Winthrop
on Nov 3, 2016 at 2:39:47 pm
This question is a bit hard to explain so I am going to try my best.
I am using the speed graph more, basically I would like to know if there is a way I can move one keyframe in the speed graph up/down and have the key-frame automatically move to the left/right the appropriate amount in order to maintain a linear speed.
Simply clicking off of the graph and moving the key frame in the timeline achieves this but it would be nice to be able to do it without having to click off. I am aware that the rove across time function more or less does this but it would be nice to be able to do it in a pinch and I feel like it is a simple as holding key or selecting both keyframes.
Thank you!
Ken Teutsch
Re: Modifying speed graph, maintaininmg a "Linear" speed.
on Nov 3, 2016 at 7:51:38 pm
I guess I'm not clear on what you are asking.
You can shift keyframes in time in the graph view the same way you can in the timeline.
