Keyframe Movement Problem
Jahari Coriano
on Nov 1, 2016 at 12:09:22 am
Ok so I have a 2D character rig and when I do a keyframe on the right arm it is smooth how it's supposed to be. But when I keyframe the left arm it is a sharp movement.
(I am new to after effects)
Here is some footage
https://gyazo.com/82096b9676d9e30ce1e3338479ee8de2
Dave Jackson
Re: Keyframe Movement Problem
on Nov 1, 2016 at 10:01:20 am
Is that rubber hose?
Maybe the rig for the left arm is upside-down, you could try re-rig - it looks like an expression/orientation issue more than a keyframe interpolation issue.
Jahari Coriano
on Nov 1, 2016 at 8:48:58 pm
it's not upside down. When I go foward to 5 frames or any frames and drag the left arm it automatically goes to the correct position
Here it is:
https://gyazo.com/d44a05e2b761a4937e53b2c3c6ee4960
I an animator. Well a starter animator but, I am getting better and better each day. Hopefully I can post my animations on youtube one day. I will be posting some things about after affects if I have a problem with it.
