Import and Replace Usuage
Martin Stacey
on Oct 27, 2016 at 3:58:37 pm
Can anyone tell me if it's possible to do this before the following item in the render queue starts rendering.
I have this setup. Comp 1, which is my main comp. Then Comp 2 which contains Comp 1 but also has a guide layer over the top.
So the workflow I would like to happen is:
Render Comp 1
Import and Replace Usage Comp 1 in Comp 2
Render Comp 2
But at the moment, it doesn't seem to do the replace until the render queue has finished rendering both comps, which is obviously not that helpful, but I may be missing something.
