After Effects: Convert Audio To Keyframes with frequency?
Eric Reed
on Oct 26, 2016 at 11:32:12 pm
I would like to be able to convert an audio track to keyframes with a certain frequency specified. (E.G. 50 Hz). From what I've seen, this is not possible; however, I would like to confirm this.
Eric
Greg Gesch
Re: After Effects: Convert Audio To Keyframes with frequency?
on Oct 27, 2016 at 1:13:13 am
Hi Erik. I'm not aware that you can do this with standard AE, however I suspect you may be able to do it with the RedGiant Soundkeys program in AE. Might be worth a look?
Eric Reed
on Oct 27, 2016 at 1:16:25 am
I will try, thank you!
Greg Gesch
on Oct 27, 2016 at 1:17:49 am
https://www.redgiant.com/products/trapcode-sound-keys/
Michael Szalapski
on Oct 27, 2016 at 2:58:28 pm
If you edit the sound clip in something like Audition to isolate the frequencies you'd like AE to respond to (and save it as a different name), you can use the convert audio to keyframes feature inside AE to pull data from that new sound file.
Granted, Sound Keys is a much faster way to do it, but if you don't already have it and don't want to spend money, you can still do it with native Adobe tools.
- The Great Szalam
