Create rotate shortcut in After Effects that's less than a degree.
Ismail Ati
on Oct 26, 2016 at 7:51:51 pm
Hello,
I'm individually rotating a bunch of images in AE. I know of the Pad+ and Pad- short cuts, they rotate the image by 1 degree but I need something smaller for more precise rotation. Anyone know how to program the Pad+ and Pad- to rotate by 0.1 degree? Thanks.
Jeff Hinkle
Re: Create rotate shortcut in After Effects that's less than a degree.
on Oct 26, 2016 at 8:26:23 pm
Command/Ctl-up arrow and down arrow seems to work.
It is easier to destroy than to create.
More fun, too.
Ismail Ati
on Oct 26, 2016 at 8:42:12 pm
Hey, doesn't seem to work for me, nothing happens.
Jeff Hinkle
on Oct 26, 2016 at 8:46:03 pm
Do you have the rotation field highlighted? Select the degree field and that should do it.
More fun, too.
Ismail Ati
on Oct 26, 2016 at 8:48:35 pm
Ok, it works now, would be nicer to have a direct shortcut for this like Pad+ or Pad- , but I'll take this. Thanks for your time.
