Trapcode Form screen space particle size
Navarro Parker
on Oct 26, 2016 at 7:08:27 pm
Posted this question over on the Trapcode section of Cow, but didn't get any responses in 4 years... So let's try here ?
Is there a setting to keep Form particles the same size no matter the distance from the camera?
Perfectly sized micro dots turn into planet-crushing meteors as my camera Z-translates through a point cloud of Form particles.
In X-Particles for C4D, they have a scale setting called "screen spaceā€ that keeps them visually the same size, no matter the distance from the camera.
Any way to achieve this in Form v2.2?
----------- END OF LINE
Dave Jackson
Re: Trapcode Form screen space particle size
on Nov 1, 2016 at 10:18:19 am
Doesn't seem to be an option in Form but it is doable in Plexus, probably not a very helpful answer though.
There is a check-box under the points-renderer for "points perspective aware"
It should take a point cloud in a similar way to Form so not too much work to translate the work if you happen to have plexus.
