Scaling from anchor point without affecting the stroke
Kevin Chan
on Oct 25, 2016 at 8:32:56 pm
Hi all,
I'm trying to create a bar graph animation. Currently, I have the anchor points set at the bottom of the rectangle so that it scales from the bottom up. The problem is that the stroke around the rectangle loses its shape even if I scale from the rectangle path and not the transform. Is there any way to fix this?
Pictures attached:
Shape layer at 100%,100% scale
Shape layer at 100%, 22% scale
