Lossless? What about the audio?!
Jerry Smith
on Oct 24, 2016 at 8:29:15 pm
So, when I export, despite the Output Module saying "Lossless", if the audio was 24 bit, then there is a loss in audio quallity isn't there?
I'm not complaining, but I just want to make sure I know what's going on.
Jerry Smith
Re: Lossless? What about the audio?!
on Oct 24, 2016 at 8:36:38 pm
Assuming you don't want to use 36 bit that is.
Jeff Pulera
on Oct 24, 2016 at 9:55:43 pm
Hi Jerry,
We need more information. What is the source? Most cameras record 16-bit audio, where are you getting 24-bit from? What's your typical workflow?
Jeff Pulera
Safe Harbor Computers
Jerry Smith
on Oct 24, 2016 at 11:31:21 pm
Source is just a 24 bit .wav audio file.
I just want to make sure that despite it saying "Lossless" in the Render Queue, it's only the video part without the audio that is actually lossless. It's just a yes or no question. If no, then I've misunderstood something.
Joel Loukus
on Oct 25, 2016 at 2:52:30 am
I think the answer to your question is that the "lossless" preset describes the video signal.
After Effects isn't a particularly good tool for doing much in the way of audio in general, I'd recommend marrying your outputs from after effects and these 24 bit sound files in Premiere.
