Strange Pre Composition Bug?
Tobias Aleksander Moen
on Oct 21, 2016 at 2:24:36 pm
I am having a pretty strange problem which have occured two times, and I have no idea why it is happening.
I will show with screenshots:
As you can see here, I have a composition with a sniper scope, and the rest of the comp is empty:
https://gyazo.com/939041de4ef3f2b7d1a697810a084a6e
Here is my main comp with the sniper scopes on:
https://gyazo.com/6af0976d56e20ca4f1c97575d6b5c74e
But when there should be nothing in the comp, this is what I see:
https://gyazo.com/7a5cf79bec50f6b86e0a84ccc9ca6e69
This is a screenshot from another project, which I not have imported into this one.
This only occur when the project is set to "Full"
https://gyazo.com/553d28fd44d6653e31580ef26ba9fbd5
I have no idea why this would be showing, but it happened another time too. The other time it happened I also had a transparent composition, but it showed a screenshot from another project I not was using. The picture will show in the rendering too...
Do anyone have any clue why this is happening?
Walter Soyka
Re: Strange Pre Composition Bug?
on Oct 21, 2016 at 2:38:10 pm
1) Try clearing your cache. Edit > Purge > All memory & disk cache.
2) Try creating a completely new comp, then copy and paste all the layers from the weird comp into the new comp.
Walter Soyka
on Oct 21, 2016 at 2:52:38 pm
Clearing the cache worked!
Thank you so much for your fast reply.
