Recreating Photoshop Wave filter
mike faulkner
on Oct 21, 2016 at 8:32:43 am
I want to recreate an effect same as
Photoshop > Filters > Wave > Type - Square
Very early versions of After effects had this Photoshop Wave filter, but they changed it
I know there is a Wave Warp effect in After effects
But I am interested in using
Wave > Type: Square option
Along with Numbers of generators, Wavelength, Amplitude, Scale
But especially 'Undefined Areas > Repeat Pixel Edges and Wrap around'
short of using a very old affects is the a 3rd party plug in or expression I could use?
Any help appreciated
Regards
Mike
Roei Tzoref
Re: Recreating Photoshop Wave filter
on Oct 21, 2016 at 12:34:16 pm
show a screenshot of the type of effect you want to create and we can offer some workarounds. this probably could be recreated using a displacement map that has this type of texture animating.
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
mike faulkner
on Oct 21, 2016 at 1:59:41 pm
Hi Roei
here is screen grab I particularly like the random button and the fact you can change parameters over a timeline
I did think maybe I could do in Photoshop over time
but last time I checked I couldn't do it
basically I have a really old machine and run an ancient version of After Effects, but its stopped working and surely there is a work around out there
thx
mike
mike faulkner
on Oct 21, 2016 at 2:03:23 pm
opps forgot image
Roei Tzoref
on Oct 21, 2016 at 2:48:42 pm
I was thinking show before and after the a full res image. I can't really tell what is going on but it seems you want the image to be divided in vertical rectangles or squares that are displacing is that correct? you can create a black and white representations of the way you want pixels to shift and use a displacement map to make the video shift it's pixels in the same way.
maybe it's something like this:
animate the displacement map fractal noise inside and the effect will be animated.
Roei Tzoref
