PrPro-AE with audio syncing- Help
Micah Derksen
on Oct 20, 2016 at 2:59:24 am
Ok, so this is kind of hard to explain. I synced 15 videos to an audio track in Premiere Pro, making the mistake of not getting each video the same length- it looks something like this (they are synced to the green audio track)- . I then linked each video as a comp. into Ae and started compositing. All worked well up until here. Then I brought in my final BG animation into AE and brought all the linked comps into a new comp. Now when I bring the new linked comp into Premiere Pro, the videos won't be synced to the audio. The reason of the new comp. is I want to track the position of each clip onto the BG.
Any ideas what I can do about the syncing problem?
Michael Szalapski
Re: PrPro-AE with audio syncing-
on Oct 20, 2016 at 2:16:21 pm
It would be a lot easier to just bring your whole Premiere sequence into AE. Go to Import>Import Premiere Pro Composition in After Effects and it will launch a tool to bring your sequence into AE with all the layers synced up just fine.
- The Great Szalam
Micah Derksen
on Oct 20, 2016 at 3:14:36 pm
That may have been a good option, except that I can't import the linked AE comps from Premiere- It says those comps are missing.
Micah Derksen
on Oct 20, 2016 at 3:27:15 pm
I should have done what you said, right at the beginning, that would have been way better than what I did- replacing each separate video as an AE comp.
