Problem with after effects light
Fabio Marino
on Oct 19, 2016 at 3:20:52 pm
I`m Trying to render a project with 3D layers, but when finished the light stay with divisions in same layers. I tried with many effects, using 3d light, trapcode lux and masked shapes with feather, but happened the same problem. What can do?
Walter Soyka
Re: Problem with after effects light
on Oct 19, 2016 at 4:32:12 pm
I'm not entirely clear on what you're trying to do; perhaps a screenshot of your entire UI will help us understand what you see better?
Please note that you cannot freely mix 2D layers with 3D layers without creating separate 3D spaces. A few things can break 3D intersection and lighting:
  • 2D layers
  • An adjustment layer
  • A 3D layer with a layer style applied
  • A 3D precomposition layer to which an effect, closed mask (with mask mode other than None), or track matte has been applied
  • A 3D precomposition layer without collapsed transformations
More here:
https://helpx.adobe.com/after-effects/using/3d-layers.html
Walter Soyka
Fabio Marino
on Oct 19, 2016 at 5:33:52 pm
This is my UI: capturadetela2016-10-19as15.10.16.png
So, i'm using layers with styles and adjustment layers.
This is the problem: 1_captura-de-tela-2016-10-19-as-15.19.31.png
The clock and sofa has bevel style, and the problem appear only in the door, i change de illustrator archive, but is the same thing.
Thanks man!!
