Switching on/off the auto-orient mode.
Kasper Bretzki
on Oct 17, 2016 at 9:01:46 am
Hello, it's already a year since I discovered Creative Cows, and I want to say, that tons of my problems were solved by you guys, I know the plain thank you is just not enough for the effort, but well, to the topic.
I finally decided to start a thread about my issue, digging into the depths of Internet didn't help in this case, and I encounter the same problem few times every month for half year already. To make it simple: I need to animate the position of a shape AND set it to auto-orient along the path. Once it's done, some frames later I need the same shape (same layer) to have it's auto-orient property turned off, while still moving along the path. Basically, I want to switch the Auto-orient on and off on a single layer. Only walkaround is by duplicating the layer, one with auto orient switch on, one with switch off. But that's another layer on a layer-heavy (usually way more than 50) composition. I recently started to experiment with connecting the shape to a null, and then animating the null, but that's only partial solution.
Would appreciate any thoughts, as this problem chew few hours every month.
