Animated OBJ disappears by adding a texture map?!
Chantal Gfeller
on Oct 14, 2016 at 12:33:11 pm
Hey Guys! ?
I'm facing an issue that drives me crazy.
I animated in AE CS6 a scene with Element 3D 1.6.0 where cupcakes fly and swirl around.
I added the diffuse texture in a later step. Everything is working out except some separate cakes, I animated in a different way.
Usually I animated the group but for 2-3 cakes I chose to animate their position and rotation with "world-transform". They are following a motion path and whenever I add the diffuse texture map, they disappear in my comp! I checked if it has something to do with the opacity but it doesn't.
Does anybody of you have an idea what the problem could be?
Thanks a lot in advance!
Cheerio
Chantal Gfeller
Re: Animated OBJ disappears by adding a texture map?!
on Oct 14, 2016 at 2:50:12 pm
E D I T :
I just realised it's because of a light in the comp that I used as an emitter for bubbly particles to follow the cake.
Still not sure how to fix it... Gonna try and keep my post updated!
Chantal Gfeller
on Oct 14, 2016 at 2:54:40 pm
pre-comps is the key... oh hell is this awkward!
