Disabling Layer Properties.
Penri Mainwaring
on Oct 14, 2016 at 10:14:03 am
Hey All,
I've created a template of a Calendar for the company I work.
There are some elements of the template that I don't want to be altered, more specifically the SCALE of some layers, is there a way to disable the SCALE property but keep the POSITION. Usually I hide these layers if I don't want them altered, but they need to move some elements around depending on location but the Scale needs to stay the same.
PM
Roei Tzoref
Re: Disabling Layer Properties.
on Oct 14, 2016 at 5:08:38 pm
[Penri Mainwaring] "There are some elements of the template that I don't want to be altered, more specifically the SCALE of some layers, is there a way to disable the SCALE property but keep the POSITION."
you could use an expression to "lock" any value. for scale you can use [100,100] and once you do, any changes to the scale won't reflect to the layer as long as the expression is active.
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
