After Affects Will Not Exporting One Of My Lights
Stephen Majors
on Oct 14, 2016 at 10:05:16 am
I'm relatively new to AE and I built a piece of 3D rotating text. I used three light sources each a different color. My first export went smoothly. No issues. I extended the time, and moved one of the lights, and now it seams as though when I export the project one of my light sources will not be recognized as existing. I'll provide as much information as can in order to fix this issue. I was trying to teach myself this program, apparently that's not in the cards.
Dave LaRonde
Re: After Affects Will Not Exporting One Of My Lights
on Oct 14, 2016 at 4:05:05 pm
[Stephen Majors] "I was trying to teach myself this program, apparently that's not in the cards"
Ooooh, that's not good. AE is in no way an intuitive application. You need to forget about doing fun stuff right away, and learn from the ground up. This will help you a lot:
https://helpx.adobe.com/after-effects/tutorials.html
Good luck.
Dave LaRonde
Promotion Producer
Roei Tzoref
on Oct 14, 2016 at 5:09:56 pm
please share some screenshots so we can see what this is about. show your setup, show the result. tell us what you expect to happen.
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
