This doesn't make any sense...
Corey Lynch
on Oct 12, 2016 at 5:17:36 am
I always render before I got to bed, so when I check my multiprocessing tab, it says that I'll only be using 2(TWO) cores when I have previously been using 8. Why did it change? I didn't change any system components or do anything in my BIOS it doesn't make any sense as to why it would change. Can someone help me?
Tudor "Ted" Jelescu
Re: This doesn't make any sense...
on Oct 12, 2016 at 12:22:55 pm
AE CC 2105 killed multiprocessing.
https://forums.adobe.com/thread/1871469
Tudor "Ted" Jelescu
Senior VFX Artist
Corey Lynch
on Oct 12, 2016 at 12:24:33 pm
Have 2014.
Walter Soyka
on Oct 12, 2016 at 4:23:07 pm
Can you post a screenshot, please, so we can see what you see?
The number of cores that will be used is highly dependent on RAM. Ae will not start a render instance unless it can get enough free RAM from the system to satisfy the minimum requirement you specify in Memory & Multiprocessing preferences.
Walter Soyka
Corey Lynch
on Oct 12, 2016 at 4:25:04 pm
I found the issue. When you open up the multiprocessing tab while media encoder is open, it will change the number. Thanks.
