Element 3D texture flickering glitch
Calvin Sang
on Oct 10, 2016 at 2:57:56 am
Hi guys and girls,
I'm having some trouble with flickering textures on a drone model I'm using with Element 3D.
As you can see here, the drone's texture keeps getting brighter and darker suddenly between frames.
https://www.dropbox.com/s/diw1llidezk1jug/Pepsi%20texture%20glitch%20test.m...
It does this no matter what texture I'm using, and also if there's no texture applied (white).
I don't believe it is an anti-aliasing issue since it appears no matter what the settings are.
SET UP
I'm using the Pro-shaders texture pack.
2 x lights
1 x spherical environment applied within Element 3D
Cassius Marques
Re: Element 3D texture flickering glitch
on Oct 10, 2016 at 7:23:53 pm
Are you using Ambient Occlusion? seems to me thats whats causing the issue. Try to remove the spinning blades from it.
Cassius Marques
http://www.zapfilmes.com
