Reduce keyframes
Matthew Beall
Reduce keyframes
on Oct 6, 2016 at 6:40:55 pm
I have some tracking data that produces a keyframe for every frame.
Is there a way to reduce/simplify those keyframes in AE?
Roei Tzoref
Re: Reduce keyframes
on Oct 6, 2016 at 7:12:31 pm
Smoothing baked keyframes will result in an uneven track. This will
miss the purpose of tracking in the first place. All tracking data is coming as frame by frame information. You should probably specify why you want to reduce the keyframes and users can offer a workaround.
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
Matthew Beall
on Oct 6, 2016 at 7:55:17 pm
There is some chatter I would like to smooth out. The tracking works great during larger moves, but when it needs to be nearly still you can notice spikes. I can probably do this manually, but I was hoping for something automatic.
Combustion had great tools for these type of instances.
Roei Tzoref
on Oct 6, 2016 at 8:00:50 pm
If it's tracking chatter and you have made sure it's the best you can get, you can apply smooth expression to the property. There are other tools for dealing with track chatter: mamoworld has some scripts for averaging trackers. Personally I use mocha in cases where there is chatter and it eliminates it completely.
Roei Tzoref
