Select multiple specific properties in a shape layer?
Tomas Brunsdon
on Oct 6, 2016 at 4:01:50 pm
Hello!
Is there a way to select every instance of a property within a shape layer (eg. 'Merge Paths 1')- either through the timeline search bar or other means? Closest I've found is a script called bq_shape_layer-navigator but it doesn't quite do this. Finding a quick way could potentially shave days off of this project!
Roei Tzoref
Re: Select multiple specific properties in a shape layer?
on Oct 7, 2016 at 9:43:32 pm
[Tomas Brunsdon] "Is there a way to select every instance of a property within a shape layer (eg. 'Merge Paths 1')- either through the timeline search bar or other means?"
yes. you can search with the timeline search bar like this:
is there a specific case where you can't use it for searching?
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
