Why are my Element 3D textures so blurry? Please Assist
Ryan Khan
on Oct 6, 2016 at 11:30:12 am
Hey there Guys,
I am having this problem with element 3D V2.2. basically I am trying to create a High Res Night Earth. I have a large texture, when I wrap it around a sphere in element it looks like this. Its very blurry and to much pixels showing up. No idea what I'm doing wrong.
I have no idea what I am doing wrong. In actual the texture is something link this
If anyone has any information on how this can be fixed please do share.
Cheers
Ryan
Tudor "Ted" Jelescu
Re: Why are my Element 3D textures so blurry? Please Assist
on Oct 6, 2016 at 1:33:57 pm
Are you previewing in E3D with Draft texture?
Do you get the same with the best render settings when you preview at full resolution from the AE comp window?
Tudor "Ted" Jelescu
Senior VFX Artist
Ryan Khan
on Oct 6, 2016 at 2:25:51 pm
Thanks for your reply,
The draft textures are off, also if you check the screenshot below, this is how it looks in full res ?
Ryan Khan
on Oct 6, 2016 at 2:38:46 pm
Actually I just found the problem I think,
After messing around with a few settings I went to File > Preferences in the Element window. I saw the default Map Size was 2048 and I was using a larger map so I changed it to 8192, re loaded the texture and wow, it suddenly fixed the problem.
Michael Szalapski
on Oct 6, 2016 at 2:39:56 pm
It looks sharp on the edges. My guess is that you've got depth of field turned on and the front of the globe isn't in focus.
- The Great Szalam
