Manually tracked Mocha data not importing into After Effects?
Austin Witherspoon
on Oct 4, 2016 at 5:32:01 am
So I tracked this TV in the background, and once the actors hand and cellphone went in front of it, I had to go frame by frame and track it.
When I export tracking data though, it only exports the stuff that was actually tracked by mocha, none of my adjustments that I manually did when the hand and phone pass in front of the TV.
How do I get my track loaded into After Effects? In mocha it plays back fine with the outline following where the TV is.
Roei Tzoref
Re: Manually tracked Mocha data not importing into After Effects?
on Oct 7, 2016 at 9:53:32 pm
the bar should be purple where you have keyframes . for some reason the manual adjustment you made were not registered. make sure you set the motion panel to manual track and the bar should turn purple on every adjustment:
more information here:
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
