Bend shape into horseshoe shape
Weston Jones
on Oct 3, 2016 at 10:31:39 pm
Seems like this would be very simple, but I can't hack it.
I'm trying to do a bend transition between the two shape layers pictured here, starting with the straight one.
Need to bend from the two ends, from the middle, so it pulling down into the 2nd image. Using CC Bend IT, it will only allow me a start/stop point, thus bending from left to right. I can't seem to do a shape morph with path keyframes either, as there are too many points and it transitions super funky.
Currently its a shape layer, from illustrator. I can raster if necessary, though would prefer to keep as shape.
Just trying to go between the two, how?! Thank you
Tudor "Ted" Jelescu
Re: Bend shape into horseshoe shape
on Oct 4, 2016 at 11:04:09 am
You can use FreeForm Pro or Free Form V2 for this or you can paste the shape from AI in a Shape layer and animate by setting keyframes and adjusting the shape.
Tudor "Ted" Jelescu
Senior VFX Artist
Kevin Camp
on Oct 4, 2016 at 5:31:15 pm
cc bend it can bend your straight sample image into the curved sample image.... set the 'start' point to the center of the image and set the end point to the right or left edge of the image, then animate the 'bend' property to bend it into the curved example.
if the image layer is cropped (not comp-sized), add grow bounds before cc bend it to extend the boundary of the layer as needed.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Weston Jones
on Oct 4, 2016 at 10:32:50 pm
Thank you, Bend It worked!
Michael Szalapski
on Oct 4, 2016 at 7:23:17 pm
Bezier Warp can do this too.
- The Great Szalam
