 | Ae Error: "UU" Key Command activates when Layers are Hidden/Revealed
on Oct 3, 2016 at 4:02:20 pm |
Hello all!
I have this strange issue. After about 15-20 minutes working in After Effects, this strange error begins to interrupt my workflow. Whenever I hide a layer or unhide a layer, it's as if the "UU" command activates on its own, splaying out all of my changes without my doing.
This isn't a DETRIMENTAL error, but for someone who has a defined workflow, this is incredibly annoying. If I restart after effects, the error goes away, and returns 20 minutes later. Is anyone else having this problem? I know it's petty, but it's annoying enough to warrant some research.
 | Re: Ae Error: "UU" Key Command activates when Layers are Hidden/Revealed on Oct 3, 2016 at 6:06:53 pm |
If you tell us the PRECISE versions of AE and OS you run -- right down to the last decimal point -- we might be able to answer you. Right now we can only speculate, and that's no good.
Dave LaRonde
Promotion Producer
 | Re: Ae Error: "UU" Key Command activates when Layers are Hidden/Revealed on Oct 3, 2016 at 6:17:06 pm |
Oh, sorry! Here's the info:
After Effects CC Version 13.8.1.38
OSX El Capitan Version 10.11.6
 | Re: Ae Error: "UU" Key Command activates when Layers are Hidden/Revealed on Oct 4, 2016 at 12:06:54 am |
There is a bug in this version that causes twirling down of layers. Read about it here:
https://forums.adobe.com/thread/2191669
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
