How to refer to the comp element is nested in
Andreas Woelfl
on Sep 29, 2016 at 9:49:41 am
Hello everybody,
I would like to write an expression for the stroke thinkness of a ShapeLayer.
The thickness should be given by a slider of an AdjustmentLayer in the MainComp.
I cannot use the expression comp("MainComp"), because there will be different copies of the MainComp and each one will have a different name. Each copy will have a different stroke thickness.
Here the scenario:
MainComp
- AdjustmentLayer
- PreComp
-- ShapeLayer
So the ShapeLayer is inside of a PreComp. The adjustment layer is inside the MainComp, together with the PreComp.
Is the some kind of expression that I can use. Instead of "thisComp" somthing like "jumpOutsideThisComp" :)
Thanks a lot for the help.
Cassius Marques
Re: How to refer to the comp element is nested in
on Sep 29, 2016 at 5:22:45 pm
The "comp" object has no method that returns where the composition is placed at. Since it can be inside more than one other composition.
But anyway if
[Andreas Woelfl] "there will be different copies of the MainComp and each one will have a different name."
why don't you reference them by name?
I really don't get it.
Cassius Marques
http://www.zapfilmes.com
