Exporting for Broadcast question
Ercong Bao
on Sep 29, 2016 at 12:54:36 am
Hello everyone, recently we have a project need to be delivered for broadcasting. These are the output requirement. Some of the export property can't be found in AE. I am running the latest version of AE CC2015.3 and trying to export this in AME
Format": DVCPro
File Extension: Mov
Aspect Ratio: 4:3 or 16:9
Resolution: 720 x 576
Bit Rate: CBR ( Where do I find this? cant find it in export option)
Bit depth: 8 bit ( Where do I find this? cant find it in export option)
Encoding Video Bit Rate: 30mbps (Where do I find this? cant find it in export option, when export H.264 there is a bar slider for you to choose, but under DVCPro, I can't seem to be able to adjust this.)
Scan type: Interlaced ( Where do I find this? cant find it in export option)
Would appreciate if anyone can help me out on this.
Audio bit depth: 20 bit ( Where do I find this? cant find it in export option there is only 16,32 bits)
Audio format :PCM ( There is AAC, and all other format except PCM)
Audio Level Range: -26dB to -23dB
Tero Ahlfors
Re: Exporting for Broadcast question
on Sep 29, 2016 at 3:38:36 am
DVCPRO is a standardized codec so there will be a bunch of settings you can't change. That said there's no 30Mbit version of DVCPRO.
https://en.wikipedia.org/wiki/DV#DVCPRO50
